Narrow band Gauge and Simulated output
First I would like to say thanks for putting together A bargain of a controller. Your attention to detail doesn’t go unnoticed. From the laser engraving to the anti-seize on the sensor threads, or the 3d printed case, I see nothing but an eye for detail.
So if I were to use the simulated output for a cheap gauge Would it be more accurate than a traditional narrow band gauge? I was thinking it could be what a narrow band gauge wanted to be in the first place. also, I didn’t see a recommendation for wire size for the harness in the instructions. I suppose 20 gauge would do?
The simulated narrowband is only suitable for a lean or rich reading for the ECU, it should not be used with a gauge.
20AWG is fine.
