TITANIA Narrowband emulation/ output Spartan 3 Lite V2
I have installed a pair of Spartan 3 Lite V2 controllers to my V8 in place of my OE (and now obsolete) NGK Titania narrowband sensors. I’m finding the ECU is applying max fuel trim + as the output from the Spartan doesn’t seem to be indicating Lambda 1- the exhaust smells rich and I’m not seeing the output “swing”.
Based on my understanding the Titania works with 0.1V Lean condition (>15.0 AFR), 1.1V rich condition (<14.0 AFR) with Lambda 1 (14.7 AFR) at 0.7V.
The more common Zirconia is 0.2V Lean, 0.8V Rich and Lambda 1 at 0.45V.
All I can see in the manual is a reference to the narrowband switching at 1V, when warming the output is 0.45-0.46V indicating Lambda 1 for a Zirconia sensor.
Is there any way to rescale the narrowband output to emulate the Titania sensor, or can the Wideband output be scaled to suit? Or do I need a different controller/ device??
If I can reprogram either output to suit are there any pointers on doing so? I regularly work with RS-232 and 485 networks so have a partial idea on what’s involved but an idiots guide would be hugely appreciated, assuming I can use the Spartan for my desired application.
To add: In the slightly longer term my intent is to go a newer standalone ECU with 0-5v dual Wideband input, but I’d rather hold fire on doing so for now.
Sorry, right now there is no way to get it working with your ECU.
That’s less than ideal.
What would adjusting the switch point of the narrowband achieve as I can’t find any explanation of how it works, other than “Switching at 1v”?
What if I were to use the 5V output and hook up a 1V zener diode?
Any other suggestions?
The only setting available have to do with the lambda of the switch point, if you want to run leaner you can set the switchpoint to higher than 1 Labmda, if you want more fuel you can set the switchpoint lower than 1 Lambda.
