I have said cable, wired the Rx an Tx to the corresponding pins of the cable, no comms to termite. Sorry for the hassle, but a document about this would be nice.
With garbled output I always check serial cable ground (as Alan mentioned) and baud rate. It’s usually from bad baud rate. Make sure you’re running 9600 8-N-1.
Hi Alan. On the Spartan 3 Lite OEM, sending new ASCII commands must be done in the bootloader? With the Flasher software?.. Can you enlighten me on this subject please? Thanks.
I’m considering to buy 2 Spatran OEM light to use in my 2.7T V6 engine. Is there any possibility to read both banks with one USB serial converter to read parameters of both sensors at the same time to see them simultaneously in Torque Pro app, or do I need to make some esp32 board to join signals and sends all params to phone
