Spartan 3 Firmware update fail
I have a Spartan 3 with Firmware 1.00
When I try to flash to Firmware 1.09 it stops after I add the COM port. Has anyone else experienced this? What needs to be done?
Same problem here. V1 with 1.00, tried update to 1.09 and as soon as I enter the com number, the screen just closes. I have another of the exact same unit that took the update just fine. The one that fails is currently in my car, and sending data to the ECU, and communicates via termite as well.
@toalan is there anything we should be trying?
Had this same problem, ended up changing the com port number, from 11 to 2 in my case and fixed and flashed.
