May I ask if Spatan2 has ability to change AFR target for narrowband output in case I need to change fuel type and still need ECU to know about the correct AFR for each fuel type
The narrowband switch point can not be changed. It switches at 1 lambda which is stoichiometric for all fuels so you should not need to adjust it for different fuels.
