Adjustable narrowband without need for restart?
Would it be possible to adjust the firmware so after running command “setnbswlamx.xxx” it would apply immediately and you wont have to do power cycle?
This would open posibilities to adjust AFR without having to shut the engine and make it much more convenient.
For the SETNBSWLAMx.xxx, you do not have to restart, the settings should take effect the instant you send the command.
Generally, I default to asking for a restart for all setting changes to be safe.
Oh I see. Well then - this product is just great. I improved my MPG by at least 15%
TY for the info, glad you like the product.
Can I ask what and why you rescaled the Narrowband output? I need to do this with my units as 14.7AFR is 0.7V in my application, not the 0.45V default.
0.45V is the most common so that is the default. Unfortunately, right now there is no way to change the voltage.
