Spartan3v2 firmware update issues
I’ve got a batch of 4 units all of which are reporting being flashed to v1.10 firmware. Incidentally, two of the units have black USB enclosures and the other 2 have red ones. First off, I’d like to point out that the v1.10 firmware is not listed on the website anywhere. The major concern I have however, is that I’m unable to flash any of these units to 1.09, 1.11 or 1.12. The reason I’d like to flash them is because I’m trying to use 2 of them in tandem and the controllers appear to freeze up after some period of runtime which is resolved by power cycling. Seeing that the firmware was older, I thought it might be a good idea to upgrade, only to discover that I can’t due to the aforementioned issue.
Is this a known issue? All of them appear to be unflashable despite following the instructions to ensure the white heater wire is disconnected to invoke the bootloader mode. The units appear to get into bootloader mode as the serial port enumerates in Windows and tools such as MobaXterm, PuTTY and others can still connect to the port, but the flasher.exe tool is never able to despite ensuring the port has been shutdown by other test applications.
For the freeze issue, set the Performance mode to 1;“SETPERF1”.
For the firmware update, please try on another PC.
We have tried the firmware update on multiple computers with the same result. What’s the deal with the firmware version not being published on the website?
The performance mode was actually originally set to 1, so we have set it to 0 at this point and will test again tomorrow.
You can send them back to me and I will flash them.
Have you tried swapping sensors and checking if the problem follows the sensor or the controller?
