Spartan 3 lite v2 issue with bootloader
Hello,
I’m having issues with getting in to the bootloader of the spartan 3 lite v2. I have connected only red and black wire - then connected the same gnd to uart along with orange and green wires, this is done on a bench by my pc, all other wires and the o2 sensor are disconnected. I can send commands and get replies which, as I understand, means that I’m not in the bootloader. When trying to flash with either 1.11 or 1.12 firmware it connects and repeatedly displays “wrong message”.
I tried measuring continuity between the heater ground and get around 11k ohms, which i would think means that they are not shorted and it should not be in the normal mode. What could be the reasoning? Does the bootloader firmware expect some kind of a handshake from the flasher app so that it would enter it? I’m using an Arduino as a serial bridge with my pc so that may be an issue - but when entering simple serial commands i get the correct output and its working.
Make sure there is common ground between computer and black electronics ground.
Also uart wires are orange and yellow, not green.
Also getting answers on uart commands means you are not in bootloader. So won’t be able to flash.
I mistyped green, was using the correct colors and yes there is commong ground. I have decided not to use uart for now and go the analog output route. Thanks for the reply.
I’ve been updating firmware to 1.12 just recently. and i had same “wrong message” in the flasher. So i’ve been debugging wires, etc. Im not completely sure what was causing this but i concluded that it was missing common ground between the board which i was using as serial bridge and power supply which i used to power spartan.
