I recently purchased a Spartan 3 lite v2 w/LSU Adv and installed it in my 944 using a combination of the OEM wiring and a separate ground for the electronics.
The led blinks slowly when I turn it on/start the car, then goes solid after a handful of seconds. This led me to believe everything was working.
I loaded up TunerStudio today and realized the wideband output reads 10 AFR (0V) all the time
I tried the power on self test by unplugging the sensor and I still get 0V all the time. Is that supposed to work? I was expecting 1.6666V and 3.333V for 5 seconds each. The LED does start blinking though! I then unwired everything and hooked both grounds and power up to the battery. Same result, 0V, nor startup sequence ![]()
If I unhook the heater ground to see if it would boot into bootloader mode, but nothing happens at all - which might be correct? I can’t see any green LED, if there is one.
So, should I bother to take the sensor out of the exhaust for the free air test if the power on test doesn’t work?
Thank you!
