ADV sensor 4 O2 sensors on can bus only 1 works
Application 2013 Audi S8
Engine 2013 Bentley W12 6.0L
turbo system single turbo
bank 1 sensor A LSU 4.9 (maxxecu internal sensor)
Bank 2 sensor B LSU 4.9 (maxxecu internal sensor)
Cylinder 1,2,3 Sensor C spartan 3 LSU 5.2
Cylinder 4,5,6 Sensor D spartan 3 LSU 5.2
Cylinder 7,8,9 sensor E spartan 3 LSU 5.2
Cylinder 10,11,12 sensor F spartan 3 LSU 5.2
I am wrapping up a project that uses 6 O2 sensors in total. 2 use the MAXXecu internal O2 inputs and are running 4.9 sensors. All spartan modules are setup on can.
Sensor D is the only one that outputs a usable lambda reading.
none of the sensors output a proper temp reading. they will show 0c and then 30c
sensor c and f current draw look correct during warmup, sensor e pulls 1.5amp forever
The status changes on all of the spartan units to 3 after a min or so of key on operation. I have verified wiring from the sensor to the units multiple times. I am not sure if I am having can collisions or what, but I am pulling my hair out on this. Does anybody have any input on where to start with these issues?
each Spartan 3 needs it’s own CAN ID and the ECU must be made aware of each CAN ID.
